소개
This guide will instruct you on how to safely remove and replace the RAM in your Toshiba Satellite L55W-C5256. You may need to do this if:
- Your device’s RAM has failed, and needs to be replaced
- You are upgrading your device’s RAM
Before beginning this replacement guide, it is recommended that you use an anti-static work mat and that you ground yourself using an anti-static wrist strap. This helps to protect your device from damage caused by static discharge. If you do not have these materials, you can find an anti-static wrist strap here, and an anti-static work mat here. To learn how to properly use an anti-static wrist strap and an anti-static work mat (recommended), see the guide found here.
필요한 것
다른 2명이 해당 안내서를 완성하였습니다.
