주요 콘텐츠로 건너뛰기
Toshiba Satellite L55W-C5256 Speaker Replacement
필요한 것
  1. Toshiba Satellite L55W-C5256 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 Speaker Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 Speaker Replacement: 3 단계, 이미지 1/1
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 Speaker Replacement: 4 단계, 이미지 1/1
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 Speaker Replacement: 5 단계, 이미지 1/1
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 Speaker Replacement: 6 단계, 이미지 1/1
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 Speaker Replacement, CPU Heatsink: 7 단계, 이미지 1/1
    • Using a Phillips #00 screw driver, remove the four 7.0 mm screws that secure the heat sink to the CPU.
  8. Toshiba Satellite L55W-C5256 Speaker Replacement: 8 단계, 이미지 1/1
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the heat sink fan to the motherboard.
  9. Toshiba Satellite L55W-C5256 Speaker Replacement: 9 단계, 이미지 1/3 Toshiba Satellite L55W-C5256 Speaker Replacement: 9 단계, 이미지 2/3 Toshiba Satellite L55W-C5256 Speaker Replacement: 9 단계, 이미지 3/3
    • Before you touch any component inside your device, ensure you are properly grounded with an anti-static band.
    • Gently lift the heat sink from the motherboard, making sure not to apply much tension to the connector cable.
    • Using your thumb and forefinger, gently unplug the connector cable from the motherboard.
    • Lift the heat sink from the motherboard.
    • If you need to replace the heat sink, check out this thermal paste guide that will walk you through the steps necessary to replace the thermal compound.
  10. Toshiba Satellite L55W-C5256 Speaker Replacement, Speakers: 10 단계, 이미지 1/2 Toshiba Satellite L55W-C5256 Speaker Replacement, Speakers: 10 단계, 이미지 2/2
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the left speaker to the motherboard.
    • Using a Phillips #00 screw driver, remove the two 7.0 mm screws that secure the right speaker to the motherboard.
  11. Toshiba Satellite L55W-C5256 Speaker Replacement: 11 단계, 이미지 1/2 Toshiba Satellite L55W-C5256 Speaker Replacement: 11 단계, 이미지 2/2
    • Before touching any component inside your device, ensure you are properly grounded with a static band.
    • Gently unplug the speaker connector cable from the motherboard.
  12. Toshiba Satellite L55W-C5256 Speaker Replacement: 12 단계, 이미지 1/1
    • Lift speakers from motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jennifer
회원 가입일: 09/23/19
777 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 145
