주요 콘텐츠로 건너뛰기
소개
This guide will help you remove the back panel of your device. No special skills are required, but you do need to know how to use a Phillips #00 screwdriver.
  1. Make sure you turn the laptop off first. Close the laptop lid and flip it over so that Toshiba logo is facing down. Close the laptop lid and flip it over so that Toshiba logo is facing down.
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver. Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Apple Watch Kits
    Screen and battery repairs just got easier.
    지금 장보기
    Apple Watch Kits
    지금 장보기
  4. Once the screws are removed, slide the battery pack out of the computer. Once the screws are removed, slide the battery pack out of the computer. Once the screws are removed, slide the battery pack out of the computer.
    • Once the screws are removed, slide the battery pack out of the computer.
  5. Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver. Use the plastic opening tool to remove the back cover from the laptop. Be aware that static discharge can cause damage to sensitive electrical components within the computer.  To avoid this you can wear an anti-static wrist strap.
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
결론
Garrett Garofalo
회원 가입일: 2018년 03월 19일
281 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S3-G3, Peak Spring 2018 UMass Dartmouth, Team S3-G3, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G3
3 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 179
