주요 콘텐츠로 건너뛰기
Toshiba Satellite L55t-B5271 RAM Replacement
필요한 것
  1. Toshiba Satellite L55t-B5271 RAM Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite L55t-B5271 RAM Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite L55t-B5271 RAM Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 RAM Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L55t-B5271 RAM Replacement: 2 단계, 이미지 2/2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 RAM Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L55t-B5271 RAM Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L55t-B5271 RAM Replacement: 3 단계, 이미지 3/3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 RAM Replacement, Back Panel: 4 단계, 이미지 1/3 Toshiba Satellite L55t-B5271 RAM Replacement, Back Panel: 4 단계, 이미지 2/3 Toshiba Satellite L55t-B5271 RAM Replacement, Back Panel: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 RAM Replacement, RAM: 5 단계, 이미지 1/3 Toshiba Satellite L55t-B5271 RAM Replacement, RAM: 5 단계, 이미지 2/3 Toshiba Satellite L55t-B5271 RAM Replacement, RAM: 5 단계, 이미지 3/3
    • This laptop does not have a RAM present. Follow instructions to replace your own.
    • Evenly press down on the clips on either side of the RAM stick.
    • To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Carson Longendorfer
회원 가입일: 03/26/18
274 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S3-G3, Peak Spring 2018 UMass Dartmouth, Team S3-G3, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G3
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
I’ve got this exact model. Stock 6GB of RAM. However, I’ve attempted to upgrade to 8GB and have tried multiple sticks of RAM and no matter what, the computer won’t recognize it. I’ve ensured it’s locked in properly, RAM is functional, even factory reset. All to no success. Any ideas?
Steve B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 389
