소개
This guide will help you to remove your broken RAM and replace it with a new one. Since the RAM is frequently updated to ensure top performance, the RAM is very easy to replace.
필요한 것
이 단계에 사용된 도구:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
