소개
This guide will assist you in removing the display of your device. You'll need to be extra careful when removing the glass screen from your device.
필요한 것
이 단계에 사용된 도구:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Unscrew the four 6mm screws from each of the laptop hinges using a Philips head #00 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
