주요 콘텐츠로 건너뛰기
Toshiba Satellite L55t-B5271 Wireless Card Replacement
필요한 것
  1. Toshiba Satellite L55t-B5271 Wireless Card Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Wireless Card Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L55t-B5271 Wireless Card Replacement: 2 단계, 이미지 2/2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Wireless Card Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: 3 단계, 이미지 3/3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Wireless Card Replacement, Back Panel: 4 단계, 이미지 1/3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Back Panel: 4 단계, 이미지 2/3 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Back Panel: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Wireless Card Replacement, Wireless Card: 5 단계, 이미지 1/2 Toshiba Satellite L55t-B5271 Wireless Card Replacement, Wireless Card: 5 단계, 이미지 2/2
    • Remove the ribbon by flipping up the tabs and using the black tweezers to gently pull the ribbon out from both ends.
  6. Toshiba Satellite L55t-B5271 Wireless Card Replacement: 6 단계, 이미지 1/3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: 6 단계, 이미지 2/3 Toshiba Satellite L55t-B5271 Wireless Card Replacement: 6 단계, 이미지 3/3
    • Remove the tape from the card.
    • Disconnect the wires using the #4 black spudger tool.
  7. Toshiba Satellite L55t-B5271 Wireless Card Replacement: 7 단계, 이미지 1/1
    • Remove the 3mm Phillips head screw with a Phillips #00 screwdriver.
  8. Toshiba Satellite L55t-B5271 Wireless Card Replacement: 8 단계, 이미지 1/2 Toshiba Satellite L55t-B5271 Wireless Card Replacement: 8 단계, 이미지 2/2
    • Pull up on the wireless card and remove it from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Noelle Dulude
회원 가입일: 03/19/18
480 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S3-G3, Peak Spring 2018 UMass Dartmouth, Team S3-G3, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 266
