주요 콘텐츠로 건너뛰기
Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement
필요한 것
  1. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: 1 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: 1 단계, 이미지 2/2
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: 2 단계, 이미지 1/1
    • Remove the panel, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: 3 단계, 이미지 1/1
    • Unscrew the 3.9 mm screw located at the bottom right of the panel.
  4. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to pry the CD drive out of the casing.
  5. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: 5 단계, 이미지 1/1
    • Once the CD drive is out far enough to grip, pull the CD drive out to the right.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Torey
회원 가입일: 01/31/13
210 평판
안내서 1개 작성함
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 회원
CPSU-MANESS-W13S7G7
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 2,265
