주요 콘텐츠로 건너뛰기
Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement
필요한 것
  1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: 1 단계, 이미지 1/3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: 1 단계, 이미지 2/3 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: 1 단계, 이미지 3/3
    • Using a plastic opening tool, remove the four plastic stickers located on the four corners of the LCD screen assembly. These plastic stickers are covering screws.
    • Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side.
  2. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: 2 단계, 이미지 2/2
    • With a plastic soft pry tool, open up the laptop display assembly by methodically prying from left to right. Be careful to not damage any internal circuitry.
    • Do not attempt to pry apart the bottom, the LCD assembly never gets fully disassembled in this tutorial.
  3. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: 3 단계, 이미지 2/2
    • Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable.
  4. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: 4 단계, 이미지 2/2
    • Carefully disconnect the camera board from the laptop. We used tweezers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Robby
회원 가입일: 02/04/13
52 평판
안내서 1개 작성함
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 회원
CPSU-MANESS-W13S7G7
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 2,578
