주요 콘텐츠로 건너뛰기
Toshiba Satellite L655D-S5095 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Keyboard Replacement: 2 단계, 이미지 1/1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Keyboard Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Keyboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 Keyboard Replacement: 5 단계, 이미지 2/2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Keyboard Replacement: 6 단계, 이미지 1/1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Keyboard Replacement: 7 단계, 이미지 1/1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jerry Wakai
회원 가입일: 01/31/13
377 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 회원
CPSU-MANESS-W13S7G7
5 회원들
안내서 6개 작성하였습니다
댓글 2개
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Christopher Tidwell - 답글
Ditto on all of it. I think I broke my ZIF connector !! Help!! 😔
salirizz67@gmail.com -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 4,908
