이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the battery locks on the bottom of the laptop.
Slide the right lock outwards, until it locks into place.
Slide and hold the left lock outwards and hold it in place.
Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
Use a plastic opening tool to pry off the plastic panel above the keyboard.
Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 2개
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Ditto on all of it. I think I broke my ZIF connector !! Help!! 😔
