주요 콘텐츠로 건너뛰기
Toshiba Satellite L655D-S5095 RAM Replacement
필요한 것
  1. Toshiba Satellite L655D-S5095 RAM Replacement, RAM: 1 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 RAM Replacement: 2 단계, 이미지 1/1
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 RAM Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L655D-S5095 RAM Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L655D-S5095 RAM Replacement: 3 단계, 이미지 3/3
    • Push the two tabs outwards, away from the RAM. The RAM should spring up.
  4. Toshiba Satellite L655D-S5095 RAM Replacement: 4 단계, 이미지 1/3 Toshiba Satellite L655D-S5095 RAM Replacement: 4 단계, 이미지 2/3 Toshiba Satellite L655D-S5095 RAM Replacement: 4 단계, 이미지 3/3
    • Pull the top RAM stick out gently.
    • Repeat steps 3 and 4 for the bottom RAM stick.
    • When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Jerry Wakai
회원 가입일: 01/31/13
377 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 회원
CPSU-MANESS-W13S7G7
5 회원들
안내서 6개 작성하였습니다
댓글 2개
Thank-You! So Much!
Sandra Crockett - 답글
Awesome & Simple! Thank-you! My Model is a Satellite P105-S6147 1GBX2 DDR2-666 Sodimm 2BG Total.
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 3,693
