주요 콘텐츠로 건너뛰기
Toshiba Satellite L655D-S5095 Screen Replacement
필요한 것
  1. Toshiba Satellite L655D-S5095 Screen Replacement, Battery: 1 단계, 이미지 1/3 Toshiba Satellite L655D-S5095 Screen Replacement, Battery: 1 단계, 이미지 2/3 Toshiba Satellite L655D-S5095 Screen Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Screen Replacement: 2 단계, 이미지 1/1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Screen Replacement, Keyboard: 3 단계, 이미지 1/1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Screen Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Screen Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 Screen Replacement: 5 단계, 이미지 2/2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Screen Replacement: 6 단계, 이미지 1/1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Screen Replacement: 7 단계, 이미지 1/1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
  8. Toshiba Satellite L655D-S5095 Screen Replacement, Screen: 8 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 Screen Replacement, Screen: 8 단계, 이미지 2/2
    • Remove stickers from four corners of laptop.
    • Remove screws underneath stickers.
  9. Toshiba Satellite L655D-S5095 Screen Replacement: 9 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 Screen Replacement: 9 단계, 이미지 2/2
    • Use plastic opening tool to pry the hinges off.
    • Remove the screen cover.
    • Unscrew the six screws on the bottom of the screen near the top of the hinges.
  10. Toshiba Satellite L655D-S5095 Screen Replacement: 10 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 Screen Replacement: 10 단계, 이미지 2/2
    • Remove cable located next to the fan.
    • Fold down screen without screen back cover to remove cable as shown.
  11. Toshiba Satellite L655D-S5095 Screen Replacement: 11 단계, 이미지 1/2 Toshiba Satellite L655D-S5095 Screen Replacement: 11 단계, 이미지 2/2
    • Unscrew both screws on each side of the screen.
    • Remove the screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christopher Camara
회원 가입일: 03/11/14
194 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-4, Calaway Spring 2014 UMass Dartmouth, Team 4-4, Calaway Spring 2014 회원
UMASSD-CALAWAY-S14S4G4
4 회원들
안내서 2개 작성하였습니다
댓글 한 개
Que éxito esta pagina , muy gran trabajo, soy de Perú y creo que este tipo de trabajos son muy bien valorados, saludos a la distancia.
Korregan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 25
전체 시간: 2,252
