주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
부품
지정된 부품이 없습니다.
  1. Locate the battery locks on the bottom of the laptop. Slide the right lock outwards, until it locks into place. Slide and hold the left lock outwards and hold it in place.
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. While holding the lock in place, slide the battery out towards you.
    • While holding the lock in place, slide the battery out towards you.
  3. Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Use a plastic opening tool to pry off the plastic panel above the keyboard.
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. LCD iPhone 스크린 수리 키트
    평생 품질 보증이 적용되는 저렴한 옵션.
    키트 쇼핑하기
    수리의 질 말고 비용을 절감하세요.
    키트 쇼핑하기
  6. Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver. Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  7. Slowly lift the keyboard out, up and towards the screen.
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  8. Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
  9. Remove stickers from four corners of laptop. Remove screws underneath stickers.
    • Remove stickers from four corners of laptop.
    • Remove screws underneath stickers.
  10. Use plastic opening tool to pry the hinges off. Remove the screen cover.
    • Use plastic opening tool to pry the hinges off.
    • Remove the screen cover.
    • Unscrew the six screws on the bottom of the screen near the top of the hinges.
    There is a large plastic cover surrounding where the keyboard was and covering the hinges. How did it come off??
    Thomas Hayes - 답글
  11. Remove cable located next to the fan. Fold down screen without screen back cover to remove cable as shown.
    • Remove cable located next to the fan.
    • Fold down screen without screen back cover to remove cable as shown.
  12. Unscrew both screws on each side of the screen. Remove the screen.
    • Unscrew both screws on each side of the screen.
    • Remove the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Camara
회원 가입일: 2014년 03월 11일
170 평판
안내서 1개 작성함
UMass Dartmouth, Team 4-4, Calaway Spring 2014 UMass Dartmouth, Team 4-4, Calaway Spring 2014 회원
UMASSD-CALAWAY-S14S4G4
4 회원들
안내서 2개 작성하였습니다
Que éxito esta pagina , muy gran trabajo, soy de Perú y creo que este tipo de trabajos son muy bien valorados, saludos a la distancia.
Korregan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 21
전체 시간: 1,884
