주요 콘텐츠로 건너뛰기
Toshiba Satellite L675D-S7015 Disk Drive Replacement
필요한 것
  1. Toshiba Satellite L675D-S7015 Disk Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the laptop on a scratch free surface, exposing underneath the laptop.
    • Identify the unlocking latches denoted by the red circles.
  2. Toshiba Satellite L675D-S7015 Disk Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L675D-S7015 Disk Drive Replacement: 2 단계, 이미지 2/2
    • Simply slide the latches outward to the unlocked position.
    • The latches should stay in the unlocked position. If not, hold them in the unlocked position.
    • With the latches in the unlocked position, slide the battery out, away from the laptop.
  3. Toshiba Satellite L675D-S7015 Disk Drive Replacement, Disk Drive: 3 단계, 이미지 1/2 Toshiba Satellite L675D-S7015 Disk Drive Replacement, Disk Drive: 3 단계, 이미지 2/2
    • Remove the the screw shown by the red circle.
    • Lift and remove the panel shown.
  4. Toshiba Satellite L675D-S7015 Disk Drive Replacement: 4 단계, 이미지 1/1
    • Remove the screw shown by the red circle.
    • Locate the small square that shows the back edge of the disk drive.
    • Push the drive in the direction shown until it cannot be pushed any further.
  5. Toshiba Satellite L675D-S7015 Disk Drive Replacement: 5 단계, 이미지 1/1
    • Pull the now revealed part of the disk drive in the direction shown until the disk drive is released.
결론
Jared Smith
회원 가입일: 03/24/19
231 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G2, Valliere Spring 2019 UMass Dartmouth, Team S1-G2, Valliere Spring 2019 회원
UMASSD-VALLIERE-S19S1G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 7
전체 시간: 109
