주요 콘텐츠로 건너뛰기
Toshiba Satellite L675D-S7016 Disk Drive Replacement
필요한 것
  1. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Back Panel Removal: 1 단계, 이미지 1/1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  2. Toshiba Satellite L675D-S7016 Disk Drive Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: 2 단계, 이미지 2/2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  3. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Disk Drive: 3 단계, 이미지 1/1
    • Remove the single 5mm Phillips #1 screw using the screwdriver.
  4. Toshiba Satellite L675D-S7016 Disk Drive Replacement: 4 단계, 이미지 1/2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: 4 단계, 이미지 2/2
    • Push the exposed portion of the Disk Drive outwards.
    • The Disk Drive will begin sliding out of its slot. Remove Disk Drive from the laptop by hand.
  5. Toshiba Satellite L675D-S7016 Disk Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: 5 단계, 이미지 2/2
    • This step is only necessary if there is a disc stuck inside the drive! If you are replacing the drive and do not need to remove a disc, this can be skipped.
    • On the front of the Disk Drive, below the eject button, insert a pin or paperclip into the hole.
    • Push the pin into hole until the Disk Drive pops out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Austin Bons
회원 가입일: 09/22/16
1,131 평판
안내서 8개 작성하였습니다
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016 회원
UCD-OLIVER-F16S2G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 343
