소개
If you have determined that your Disk Drive is faulty, this guide will walk you through the removal steps. This piece of the laptop is easily removed and reinstalled. An easy fix for novices.
필요한 것
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
