주요 콘텐츠로 건너뛰기
Toshiba Satellite L675D-S7016 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Hard Drive Replacement: 3 단계, 이미지 1/3 Toshiba Satellite L675D-S7016 Hard Drive Replacement: 3 단계, 이미지 2/3 Toshiba Satellite L675D-S7016 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Back Panel Removal: 4 단계, 이미지 1/1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Hard Drive Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L675D-S7016 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/2 Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
결론
To install a new Hard Drive, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Austin Bons
회원 가입일: 09/22/16
1,131 평판
안내서 8개 작성하였습니다
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016 회원
UCD-OLIVER-F16S2G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 1,029
