소개
After going through the Troubleshooting guide, and you hear that your laptop is "clicky" or that the hard drive is not connect, this guide will guide you through the removal of the hard drive.
필요한 것
Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
Slide the hard drive to the left, using the silver tab.
Pull up the silver tab, removing the hard drive from the slot.
To install a new Hard Drive, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
