주요 콘텐츠로 건너뛰기
Toshiba Satellite L675D-S7016 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L675D-S7016 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite L675D-S7016 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite L675D-S7016 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 1개 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 2개 Toshiba Satellite L675D-S7016 Keyboard Replacement, Keyboard: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  5. Toshiba Satellite L675D-S7016 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite L675D-S7016 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  6. Toshiba Satellite L675D-S7016 Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Toshiba Satellite L675D-S7016 Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  7. Toshiba Satellite L675D-S7016 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 Toshiba Satellite L675D-S7016 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 Toshiba Satellite L675D-S7016 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Austin Bons
회원 가입일: 09/22/16
1,131 평판
안내서 8개를 작성함
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016 회원
UCD-OLIVER-F16S2G2
5 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 22
전체 시간: 840
