주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If your Toshiba Satellite L755-S5244 will not hold charge, has a very short battery life, or is overheating during use or charging, it may need replacement. The battery on the Toshiba Satellite L755-S5244 usually has a lifetime of 3 to 6 years and will steadily lose its ability to hold charge over time. The Satellite L755 uses a lithium-ion battery. Replacing the battery does not require any tools, or special parts, except a replacement battery.
  1. Turn the laptop upside-down, and face the battery toward you. Pull out the two tabs on either side of the battery. The tab on the right will stay pulled out, and the left one must be held out.
    • Turn the laptop upside-down, and face the battery toward you.
    • Pull out the two tabs on either side of the battery. The tab on the right will stay pulled out, and the left one must be held out.
    • Remove the battery and release the left tab.
  2. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    키트 쇼핑하기
    Enough RAM
    For All The Tabs
    키트 쇼핑하기
결론
The battery is successfully replaced.
Anthony Buschini
회원 가입일: 2019년 04월 05일
271 평판
안내서 2개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 178
