주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If your Toshiba Satellite L755-S5244 disk drive is not reading disks, then it should be replaced. The removal of or the replacement of the disk drive will require this guide.
부품
지정된 부품이 없습니다.
  1. Unsnap and remove the bar above  the keyboard.
    • Unsnap and remove the bar above the keyboard.
  2. Unscrew the four 4mm Phillips #0 screws beneath the bar.
    • Unscrew the four 4mm Phillips #0 screws beneath the bar.
  3. 플러그없이 공부하세요
    Mac 배터리 수리 키트
    수리 키트 쇼핑하기
    플러그없이 공부하세요
    Mac 배터리 수리 키트
    수리 키트 쇼핑하기
  4. Pull keyboard up and partially out. Detach conductor ribbon.
    • Pull keyboard up and partially out.
    • Detach conductor ribbon.
    • Slide keyboard out completely.
  5. Remove the seven 4mm Phillips #0 screws beneath the keyboard.
    • Remove the seven 4mm Phillips #0 screws beneath the keyboard.
    • After the screws are removed, remove the face plate to reveal the motherboard.
  6. Lift up the flap and there will be two 2 mm Phillips screws beneath that will need to be unscrewed to pull the disk drive out.
    • Lift up the flap and there will be two 2 mm Phillips screws beneath that will need to be unscrewed to pull the disk drive out.
  7. Now the disk drive will be able to be removed from the motherboard by sliding the drive to the right.
    • Now the disk drive will be able to be removed from the motherboard by sliding the drive to the right.
결론
Victor Salazar
회원 가입일: 2019년 04월 04일
97 평판
안내서 1개 작성함
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 102
