주요 콘텐츠로 건너뛰기
Toshiba Satellite L755-S5244 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite L755-S5244 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Toshiba Satellite L755-S5244 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • As a safety precaution, unplug the laptop and remove the battery.
  2. Toshiba Satellite L755-S5244 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the two 3mm Phillips #0 screws on the bottom of the corner panel.
    • The screws do not need to be removed completely from the panel, just loosened out of the sockets beneath the panel. When the screws are completely loosened, they can be left in the panel.
  3. Toshiba Satellite L755-S5244 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Use the cutaway to lift the panel away from the lap top.
  4. Toshiba Satellite L755-S5244 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the single 3mm Phillips #0 screw securing the hard drive (hard drive not pictured).
    • Once the screw is removed, push the hard drive up (away from the battery) to disconnect it from the laptop.
    • You are now able to lift the hard drive out of the laptop.
결론
Carter Willson
회원 가입일: 04/15/19
248 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 688
