주요 콘텐츠로 건너뛰기
Toshiba Satellite L755-S5244 Motherboard Replacement
필요한 것
  1. Toshiba Satellite L755-S5244 Motherboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Unsnap and remove the bar above the keyboard.
  2. Toshiba Satellite L755-S5244 Motherboard Replacement: 2 단계, 이미지 1/1
    • Unscrew the four 4mm Phillips #0 screws beneath the bar.
  3. Toshiba Satellite L755-S5244 Motherboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L755-S5244 Motherboard Replacement: 3 단계, 이미지 2/2
    • Pull keyboard up and partially out.
    • Detach conductor ribbon.
    • Slide keyboard out completely.
  4. Toshiba Satellite L755-S5244 Motherboard Replacement, Disk Drive: 4 단계, 이미지 1/1
    • Remove the seven 4mm Phillips #0 screws beneath the keyboard.
    • After the screws are removed, remove the face plate to reveal the motherboard.
  5. Toshiba Satellite L755-S5244 Motherboard Replacement: 5 단계, 이미지 1/1
    • Lift up the flap and there will be two 2 mm Phillips screws beneath that will need to be unscrewed to pull the disk drive out.
  6. Toshiba Satellite L755-S5244 Motherboard Replacement: 6 단계, 이미지 1/1
    • Now the disk drive will be able to be removed from the motherboard by sliding the drive to the right.
  7. Toshiba Satellite L755-S5244 Motherboard Replacement, Motherboard and Fan: 7 단계, 이미지 1/1
    • Carefully remove the 2 conductor ribbons.
    • Do not tear the yellow tape covering the upper conductor ribbon if possible.
    • The lower right ribbon may be removed at either the left or right ends by flipping up the black tab.
  8. Toshiba Satellite L755-S5244 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the indicated conduit by gently pulling it away from the motherboard.
  9. Toshiba Satellite L755-S5244 Motherboard Replacement: 9 단계, 이미지 1/3 Toshiba Satellite L755-S5244 Motherboard Replacement: 9 단계, 이미지 2/3 Toshiba Satellite L755-S5244 Motherboard Replacement: 9 단계, 이미지 3/3
    • Remove the 5mm Phillips #0 screw in the middle of the motherboard, and the 4mm Phillips #0 screw on the upper left near the fan.
    • Remove the four 4mm Phillips #0 screws under the edge covering flaps.
    • Carefully lift out the motherboard and fan.
    • To detach the fan, remove the two 2mm Phillips #0 screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anthony Buschini
회원 가입일: 04/05/19
304 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 21
전체 시간: 1,151
