이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
To replace the Satellite L755 motherboard you will need a Phillips (PH0) screwdriver. The motherboard is fragile and should not be bent or pried away from other parts or forced into place since it may break.
필요한 것
Remove the seven 4mm Phillips #0 screws beneath the keyboard.
After the screws are removed, remove the face plate to reveal the motherboard.
Remove the 5mm Phillips #0 screw in the middle of the motherboard, and the 4mm Phillips #0 screw on the upper left near the fan.
Remove the four 4mm Phillips #0 screws under the edge covering flaps.
Carefully lift out the motherboard and fan.
To detach the fan, remove the two 2mm Phillips #0 screws.
다른 한 분이 해당 안내서를 완성하였습니다.
