이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Pull keyboard up and partially out.
Detach conductor ribbon.
Slide keyboard out completely.
Remove the seven 4mm Phillips #0 screws beneath the keyboard.
After the screws are removed, remove the face plate to reveal the motherboard.
Lift up the flap and there will be two 2 mm Phillips screws beneath that will need to be unscrewed to pull the disk drive out.
Now the disk drive will be able to be removed from the motherboard by sliding the drive to the right.
Remove the indicated conduit by gently pulling it away from the motherboard.
Remove the 5mm Phillips #0 screw in the middle of the motherboard, and the 4mm Phillips #0 screw on the upper left near the fan.
Remove the four 4mm Phillips #0 screws under the edge covering flaps.
Carefully lift out the motherboard and fan.
To detach the fan, remove the two 2mm Phillips #0 screws.
다른 한 분이 해당 안내서를 완성하였습니다.
