주요 콘텐츠로 건너뛰기
Toshiba Satellite L755-S5244 RAM Replacement
필요한 것
  1. Toshiba Satellite L755-S5244 RAM Replacement, RAM: 1 단계, 이미지 1/2 Toshiba Satellite L755-S5244 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Loosen the two 3mm Phillips #0 screws securing the hard drive panel. The panel will retain the screws, so do not remove them completely.
    • Remove the panel from the laptop (the hard drive does not need to be removed).
  2. Toshiba Satellite L755-S5244 RAM Replacement: 2 단계, 이미지 1/2 Toshiba Satellite L755-S5244 RAM Replacement: 2 단계, 이미지 2/2
    • Loosen the three 3mm Phillips #0 screws that secure the center panel. The screws are retained by the cover, so do not remove them completely.
    • Remove the panel by pulling out to the right.
    • The two RAM sticks are stacked, one on top of the other.
  3. Toshiba Satellite L755-S5244 RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L755-S5244 RAM Replacement: 3 단계, 이미지 2/2
    • Each RAM stick has two (2) snap locks, one on each end. In the image the bottom snap is obscured by the cable.
  4. Toshiba Satellite L755-S5244 RAM Replacement: 4 단계, 이미지 1/1
    • Move the retaining clips out of their locking position, allowing the RAM stick to pop up.
    • Lift the free end of the RAM stick until the stick can be freely removed from its slot.
  5. Toshiba Satellite L755-S5244 RAM Replacement: 5 단계, 이미지 1/1
    • The RAM stick has a notch that is not centered on the stick. Be sure to take note of the RAM stick's orientation for reinstallation
  6. Toshiba Satellite L755-S5244 RAM Replacement: 6 단계, 이미지 1/1
    • Repeat for the second RAM stick.
결론
Carter Willson
회원 가입일: 04/15/19
248 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 318
