주요 콘텐츠로 건너뛰기
Toshiba Satellite L755D-S5150 Battery Removal
  1. Toshiba Satellite L755D-S5150 Battery Removal, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L755D-S5150 Battery Removal, Battery: 1 단계, 이미지 2/2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kyler Clonts
회원 가입일: 10/06/16
258 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I've got a trouble when I try to charge the battery, when I plug in the power supply charger at the laptop it is lit led one and three in the front panel, that is OK, but after a few seconds all leds blinking and the charge is breaking on the screen appear no battery plug in. I replaced the battery pack for a new one, but the trouble continuos……
Iván Andrade - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 232
