주요 콘텐츠로 건너뛰기
Toshiba Satellite L755D-S5150 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L755D-S5150 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Keyboard Replacement, Keyboard: 2 단계, 이미지 1/1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Keyboard Replacement: 3 단계, 이미지 1/1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Keyboard Replacement: 4 단계, 이미지 1/1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
결론
Replace after you are done with your goal replacement.
다른 한 분이 해당 안내서를 완성하였습니다.
Shaheedah
회원 가입일: 10/06/16
276 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 881
