주요 콘텐츠로 건너뛰기
Toshiba Satellite L755D-S5150 Motherboard Replacement
필요한 것
  1. Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Motherboard Replacement, Keyboard: 2 단계, 이미지 1/1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Motherboard Replacement: 3 단계, 이미지 1/1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/2 Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/2
    • Using the Phillips PH00 screwdriver remove the three 4mm screws from the cover for the RAM.
    • Use the Phillips PH00 to remove the one 4mm screw that holds the ODD.
    • Slide the ODD outward.
    • Removing the RAM is not necessary
    • The ODD is also commonly referred to as a CD-ROM.
  6. Toshiba Satellite L755D-S5150 Motherboard Replacement: 6 단계, 이미지 1/1
    • Use the Phillips PH00 screwdriver to remove one 4mm screw.
    • Use the Phillips PH00 screwdriver to remove the two 3mm screws from the fan.
    • The motherboard will be accessed from below the keyboard, therefore you will not need to take out the bottom of the laptop.
  7. Toshiba Satellite L755D-S5150 Motherboard Replacement: 7 단계, 이미지 1/1
    • Use the Phillips PH00 to unscrew the fifteen 4mm screws holding down the motherboard.
  8. Toshiba Satellite L755D-S5150 Motherboard Replacement: 8 단계, 이미지 1/2 Toshiba Satellite L755D-S5150 Motherboard Replacement: 8 단계, 이미지 2/2
    • Lift the motherboard and disconnect the 4 pin connector on the bottom side.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Shaheedah
회원 가입일: 10/06/16
276 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
This my laptop for now .
mouhmmad ghassan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,049
