주요 콘텐츠로 건너뛰기
Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement
필요한 것
  1. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: 1 단계, 이미지 2/2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Keyboard: 2 단계, 이미지 1/1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: 3 단계, 이미지 1/1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: 4 단계, 이미지 1/1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Optical Disc Drive: 5 단계, 이미지 1/1
    • Use the screwdiver and the Phillips PH00 to unscrew the three, 4mm screws for the RAM compartment
  6. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: 6 단계, 이미지 1/2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: 6 단계, 이미지 2/2
    • Use the Phillips PH00 to remove the 4mm screw that holds the ODD.
    • Slide the ODD outward.
  7. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: 7 단계, 이미지 1/1
    • Remove the two 4mm screws and the plate attached to the ODD.
결론
Michael Griskewicz
회원 가입일: 10/06/16
159 평판
안내서 1개 작성함
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 347
