주요 콘텐츠로 건너뛰기
Toshiba Satellite L755D-S5150 RAM Replacement
필요한 것
  1. Toshiba Satellite L755D-S5150 RAM  Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite L755D-S5150 RAM  Replacement, Battery: 1 단계, 이미지 2/2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 RAM  Replacement, RAM Chip: 2 단계, 이미지 1/3 Toshiba Satellite L755D-S5150 RAM  Replacement, RAM Chip: 2 단계, 이미지 2/3 Toshiba Satellite L755D-S5150 RAM  Replacement, RAM Chip: 2 단계, 이미지 3/3
    • Using the Phillips PH00 screwdriver unscrew the three 4mm screws for the cover of the Ram compartment.
    • Now remove the cover for the Ram compartment.
  3. Toshiba Satellite L755D-S5150 RAM  Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L755D-S5150 RAM  Replacement: 3 단계, 이미지 2/2
    • Using both hands, gently push the two metal claps on either side of the top RAM chip outward.
    • The RAM chip will then pop up at an angle, allowing you to pull it out.
    • Repeat the above step for the second RAM chip
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyler Clonts
회원 가입일: 10/06/16
258 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 382
