주요 콘텐츠로 건너뛰기
Toshiba Satellite L775D-S7340 CMOS Battery Replacement
필요한 것
  1. Toshiba Satellite L775D-S7340 CMOS Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 CMOS Battery Replacement: 2 단계, 이미지 1/1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 CMOS Battery Replacement: 3 단계, 이미지 1/1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove the one 4.6 mm screw holding on the cover located on the bottom center of the laptop.
  5. Toshiba Satellite L775D-S7340 CMOS Battery Replacement: 5 단계, 이미지 1/1
    • Use the plastic opening tool to pry open the CMOS battery cover. Wedge the prying tool in, beginning at the indent in the cover.
  6. Toshiba Satellite L775D-S7340 CMOS Battery Replacement: 6 단계, 이미지 1/1
    • Use another prying tool to pry up along the edges of the cover. Continue prying up around the edges until the cover is open and remove it.
  7. Toshiba Satellite L775D-S7340 CMOS Battery Replacement: 7 단계, 이미지 1/1
    • Using the pointed side of the spudger, remove the CMOS battery by pushing down on the tab that secures the battery in place.
    • The CMOS battery should pop up or out of its holder.
결론
Elizabeth Sadewasser
회원 가입일: 09/21/17
498 평판
안내서 3개 작성하였습니다
Washington State, Team S4-G120, Phelps-Hillen Fall 2017 Washington State, Team S4-G120, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S4G120
6 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 26
전체 시간: 6,145
