주요 콘텐츠로 건너뛰기
Toshiba Satellite L775D-S7340 Optical Disk Drive Replacement
필요한 것
  1. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: 2 단계, 이미지 1/1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: 3 단계, 이미지 1/1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement, Optical Disk Drive: 4 단계, 이미지 1/1
    • Remove the (mm) screw in between the two white manufacturer’s stickers using the Phillips #1 screwdriver.
  5. Toshiba Satellite L775D-S7340 Optical Disk Drive  Replacement: 5 단계, 이미지 1/1
    • Gently slide the optical disk drive out of the computer.
결론
Madeline Park
회원 가입일: 09/21/17
441 평판
안내서 4개 작성하였습니다
Washington State, Team S4-G120, Phelps-Hillen Fall 2017 Washington State, Team S4-G120, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S4G120
6 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 206
