주요 콘텐츠로 건너뛰기
Toshiba Satellite L775D-S7340 RAM Replacement
필요한 것
  1. Toshiba Satellite L775D-S7340 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is unplugged and powered off.
    • Locate the battery latches on the underside of the laptop.
  2. Toshiba Satellite L775D-S7340 RAM Replacement: 2 단계, 이미지 1/1
    • Slide the right latch to the right until you hear it lock into place.
    • Slide the left latch to the left and hold it.
  3. Toshiba Satellite L775D-S7340 RAM Replacement: 3 단계, 이미지 1/1
    • Slide the battery out towards you.
  4. Toshiba Satellite L775D-S7340 RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove the one 4.6 mm screw holding on the cover located on the bottom center of the laptop.
  5. Toshiba Satellite L775D-S7340 RAM Replacement: 5 단계, 이미지 1/1
    • Use the plastic opening tool to pry open the RAM cover. Wedge the prying tool in, beginning at the indent in the cover.
  6. Toshiba Satellite L775D-S7340 RAM Replacement: 6 단계, 이미지 1/1
    • Use another prying tool to pry up along the edges of the cover. Continue prying up around the edges until the cover is open and remove it.
  7. Toshiba Satellite L775D-S7340 RAM Replacement: 7 단계, 이미지 1/2 Toshiba Satellite L775D-S7340 RAM Replacement: 7 단계, 이미지 2/2
    • Push the two top tabs outwards and the top stick of RAM will pop up. Gently remove the stick of RAM by pulling it out.
  8. Toshiba Satellite L775D-S7340 RAM Replacement: 8 단계, 이미지 1/1
    • Push the two bottom tabs outwards and the bottom stick of RAM will pop up. Gently remove the bottom stick of RAM by pulling it out.
결론
Elizabeth Sadewasser
회원 가입일: 09/21/17
498 평판
안내서 3개 작성하였습니다
Washington State, Team S4-G120, Phelps-Hillen Fall 2017 Washington State, Team S4-G120, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S4G120
6 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 400
