주요 콘텐츠로 건너뛰기
Toshiba Satellite L855-S5119 Optical Drive Replacement
필요한 것
  1. Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: 1 단계, 이미지 1/3 Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: 1 단계, 이미지 2/3 Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: 1 단계, 이미지 3/3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  2. Toshiba Satellite L855-S5119 Optical Drive Replacement, Optical Drive: 2 단계, 이미지 1/2 Toshiba Satellite L855-S5119 Optical Drive Replacement, Optical Drive: 2 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  3. Toshiba Satellite L855-S5119 Optical Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L855-S5119 Optical Drive Replacement: 3 단계, 이미지 2/2
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler Shafer
회원 가입일: 02/12/18
426 평판
안내서 3개 작성하였습니다
Washington State, Team S1-G5, Lobnitz Spring 2018 Washington State, Team S1-G5, Lobnitz Spring 2018 회원
WSU-LOBNITZ-S18S1G5
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 249
