주요 콘텐츠로 건너뛰기
Toshiba Satellite L875D-S7210 Keyboard Replacement
필요한 것
  1. Toshiba Satellite L875D-S7210 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Starting on either side, use a metal spudger to pry out the long, narrow plastic covering at the bottom of the keyboard.
  2. Toshiba Satellite L875D-S7210 Keyboard Replacement: 2 단계, 이미지 1/1
    • Gently remove the plastic strip from the keyboard.
  3. Toshiba Satellite L875D-S7210 Keyboard Replacement: 3 단계, 이미지 1/1
    • Using your hands, gently lift the keyboard out of the computer. The keyboard will still be attached to the computer so be careful not to pull too hard.
  4. Toshiba Satellite L875D-S7210 Keyboard Replacement: 4 단계, 이미지 1/1
    • Find the ribbon cable that connects the keyboard to the computer.
  5. Toshiba Satellite L875D-S7210 Keyboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite L875D-S7210 Keyboard Replacement: 5 단계, 이미지 2/2
    • Place the metal spudger underneath the lockable connector.
    • Lift up to unlock the lockable connector
    • Remove the ribbon cable from the keyboard and you will have successfully removed from your laptop. Reverse this process to attach the new keyboard.
결론
Ian M Sloop
회원 가입일: 10/20/18
667 평판
안내서 4개 작성하였습니다
UC Davis, Team S7-G7, Lore Fall 2018 UC Davis, Team S7-G7, Lore Fall 2018 회원
UCD-LORE-F18S7G7
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 693
