주요 콘텐츠로 건너뛰기
Toshiba Satellite L875D-S7210 RAM Replacement
필요한 것
  1. Toshiba Satellite L875D-S7210 RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Flip the laptop over and locate the screw beneath the left battery latch.
  2. Toshiba Satellite L875D-S7210 RAM Replacement: 2 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver to remove the screw.
  3. Toshiba Satellite L875D-S7210 RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite L875D-S7210 RAM Replacement: 3 단계, 이미지 2/2
    • Using a metal spudger, slip it into the groove and gently pry open the cover.
  4. Toshiba Satellite L875D-S7210 RAM Replacement: 4 단계, 이미지 1/1
    • Locate the RAM card at the top left corner closest to the bottom of the battery.
  5. Toshiba Satellite L875D-S7210 RAM Replacement: 5 단계, 이미지 1/1
    • Using two fingers, push the two levers outwards in opposite directions of each other to release the RAM card.
  6. Toshiba Satellite L875D-S7210 RAM Replacement: 6 단계, 이미지 1/1
    • When done correctly, the RAM card should pop up like this.
  7. Toshiba Satellite L875D-S7210 RAM Replacement: 7 단계, 이미지 1/1
    • Remove the existing RAM card and insert the your new RAM by snapping the RAM in place. Make sure the notch on your RAM card matches up with the slot.
결론
Ian M Sloop
회원 가입일: 10/20/18
667 평판
안내서 4개 작성하였습니다
UC Davis, Team S7-G7, Lore Fall 2018 UC Davis, Team S7-G7, Lore Fall 2018 회원
UCD-LORE-F18S7G7
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 366
