주요 콘텐츠로 건너뛰기
Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement
필요한 것
  1. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: 2 단계, 이미지 1/1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement, CD/DVD Drive: 3 단계, 이미지 1/1
    • Remove the back panel by removing the three labeled screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: 4 단계, 이미지 1/2 Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: 4 단계, 이미지 2/2
    • Locate and remove the circled screw with a Phillips #0 screwdriver.
  5. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: 5 단계, 이미지 1/1
    • Use the plastic opening tool to pry the CD/DVD drive out of the frame.
  6. Toshiba Satellite M305D-S4829 CD/DVD Drive Replacement: 6 단계, 이미지 1/1
    • Gently remove the CD/DVD drive from the laptop body.
결론
Michael Jensen
회원 가입일: 04/18/11
425 평판
안내서 6개 작성하였습니다
Cal Poly, Team 4-3, Regan Spring 2011 Cal Poly, Team 4-3, Regan Spring 2011 회원
CPSU-REGAN-S11S4G3
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,066
