주요 콘텐츠로 건너뛰기
Toshiba Satellite M305D-S4829 Keyboard Replacement
필요한 것
  1. Toshiba Satellite M305D-S4829 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Keyboard Replacement: 2 단계, 이미지 1/1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/1
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Keyboard Replacement: 4 단계, 이미지 1/2 Toshiba Satellite M305D-S4829 Keyboard Replacement: 4 단계, 이미지 2/2
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Keyboard Replacement: 5 단계, 이미지 1/2 Toshiba Satellite M305D-S4829 Keyboard Replacement: 5 단계, 이미지 2/2
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Keyboard Replacement: 6 단계, 이미지 1/2 Toshiba Satellite M305D-S4829 Keyboard Replacement: 6 단계, 이미지 2/2
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Keyboard Replacement: 7 단계, 이미지 1/2 Toshiba Satellite M305D-S4829 Keyboard Replacement: 7 단계, 이미지 2/2
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Keyboard Replacement: 8 단계, 이미지 1/1
    • Your keyboard has now been successfully removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Michael Jensen
회원 가입일: 04/18/11
425 평판
안내서 6개 작성하였습니다
Cal Poly, Team 4-3, Regan Spring 2011 Cal Poly, Team 4-3, Regan Spring 2011 회원
CPSU-REGAN-S11S4G3
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 11
전체 시간: 4,561
