주요 콘텐츠로 건너뛰기
Toshiba Satellite M35X-S114 Battery Replacement
  1. Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: 1 단계, 이미지 2개 중 1개 Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: 1 단계, 이미지 2개 중 2개
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: 2 단계, 이미지 2개 중 1개 Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: 2 단계, 이미지 2개 중 2개
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: 3 단계, 이미지 2개 중 1개 Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: 3 단계, 이미지 2개 중 2개
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
결론
작성자
3다른 기여자 명과 함께
Nathan Jansen
회원 가입일: 09/08/14
206 평판
안내서 1개를 작성함
CSU Fullerton, Team 2-4, Bruce Fall 2014 CSU Fullerton, Team 2-4, Bruce Fall 2014 회원
CSUF-BRUCE-F14S2G4
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 491
