주요 콘텐츠로 건너뛰기
Toshiba Satellite M35X-S114 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: 1 단계, 이미지 2개 중 1개 Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: 1 단계, 이미지 2개 중 2개
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: 2 단계, 이미지 2개 중 1개 Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: 2 단계, 이미지 2개 중 2개
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: 3 단계, 이미지 2개 중 1개 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: 3 단계, 이미지 2개 중 2개
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: 4 단계, 이미지 3개 중 1개 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: 4 단계, 이미지 3개 중 2개 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: 4 단계, 이미지 3개 중 3개
    • Locate the Hard Drive.
    • Locate the screw near the Hard Drive.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
  5. Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: 5 단계, 이미지 2개 중 1개 Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: 5 단계, 이미지 2개 중 2개
    • Please note that the hard drive from the laptop used is missing.
    • Slide the hard drive out.
    • The hard drive may not slide out easily, and may require a little bit of force in order to be disconnected from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Christian Mayorga
회원 가입일: 09/09/14
219 평판
안내서 2개를 작성함
CSU Fullerton, Team 2-4, Bruce Fall 2014 CSU Fullerton, Team 2-4, Bruce Fall 2014 회원
CSUF-BRUCE-F14S2G4
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 16
전체 시간: 1,962
