주요 콘텐츠로 건너뛰기
Toshiba Satellite M35X-S114 RAM Replacement
필요한 것
  1. Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: 1 단계, 이미지 1/2 Toshiba Satellite M35X-S114 RAM Replacement, Unlock the Battery from its Compartment: 1 단계, 이미지 2/2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: 2 단계, 이미지 1/2 Toshiba Satellite M35X-S114 RAM Replacement, Move the Battery's Release Switch: 2 단계, 이미지 2/2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: 3 단계, 이미지 1/2 Toshiba Satellite M35X-S114 RAM Replacement, Remove the Battery: 3 단계, 이미지 2/2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: 4 단계, 이미지 1/3 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: 4 단계, 이미지 2/3 Toshiba Satellite M35X-S114 RAM Replacement, Remove the screw securing the RAM cover.: 4 단계, 이미지 3/3
    • Locate the RAM cover around the middle left-hand side of the device.
    • Locate the screw on the RAM cover.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
    • Carefully remove the RAM access hatch.
  5. Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: 5 단계, 이미지 1/2 Toshiba Satellite M35X-S114 RAM Replacement, Remove the RAM sticks.: 5 단계, 이미지 2/2
    • Locate the four silver clips holding the RAM sticks.
    • There is a total of two RAM chips and four silver clips. Two silver clips hold one RAM stick. Remove one RAM stick at a time.
    • Use your fingers from separate hands to pull back the two silver clips away from the sides of the RAM stick.
    • Repeat this step for the other RAM stick.
  6. Toshiba Satellite M35X-S114 RAM Replacement: 6 단계, 이미지 1/1
    • Gently pull the RAM stick out from its slot.
결론
Christian Mayorga
회원 가입일: 09/09/14
219 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team 2-4, Bruce Fall 2014 CSU Fullerton, Team 2-4, Bruce Fall 2014 회원
CSUF-BRUCE-F14S2G4
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 418
