소개
This guide will demonstrate how to dismantle and replace components of your computers display (screen).
  1. Using a bladed tool, gently pry up the display hinge cover. Using a bladed tool, gently pry up the display hinge cover.
    • Using a bladed tool, gently pry up the display hinge cover.
  2. After folding the display completely back, lift up on the display hinge cover and remove it. After folding the display completely back, lift up on the display hinge cover and remove it.
    • After folding the display completely back, lift up on the display hinge cover and remove it.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Remove the keyboard. For keyboard removal instructions, see the keyboard guide here: Toshiba Satellite M45 Keyboard Replacement
  5. Remove the black electrical tape covering the black-and-white antenna cable. There will be 2-3 pieces of tape.
    • Remove the black electrical tape covering the black-and-white antenna cable. There will be 2-3 pieces of tape.
    • After the tape has been removed, close the laptop display, flip the laptop over, and disconnect the black-and-white antenna cables from the WiFi Card.
    • Once the antenna cables are disconnected from the modem card, flip the laptop back over and open the display.
  6. Remove the two screws securing the display hinges with a #1 size Phillips head screwdriver. It is recommended to keep the screws in a small cup so that you don't lose them. Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side. Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side.
    • Remove the two screws securing the display hinges with a #1 size Phillips head screwdriver. It is recommended to keep the screws in a small cup so that you don't lose them.
    • Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side.
  7. Remove the display's video connector by gently pulling up.
    • Remove the display's video connector by gently pulling up.
    • Remove the black-and-white antenna cable from the groove.
    • Your display can now be removed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Aryn Pauly
회원 가입일: 2010년 04월 29일
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-42, Garner Spring 2010 Cal Poly, Team 10-42, Garner Spring 2010 회원
CPSU-GARNER-S10S10G42
5 회원들
안내서 10개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 7,841
