주요 콘텐츠로 건너뛰기
Toshiba Satellite M45 Keyboard Replacement
필요한 것
  1. Toshiba Satellite M45 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Toshiba Satellite M45 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Toshiba Satellite M45 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
    • Push back the screen until it is flat with the laptop.
    • Gently remove the clips that connect the panel to the screen.
  2. Toshiba Satellite M45 Keyboard Replacement: 2 단계, 이미지 1/3 Toshiba Satellite M45 Keyboard Replacement: 2 단계, 이미지 2/3 Toshiba Satellite M45 Keyboard Replacement: 2 단계, 이미지 3/3
    • Use the Phillips #1 screwdriver to remove the two screws.
    • Gently pry the keyboard from the laptop using the blue iFixit opening tool.
    • Slowly lift the keyboard away from the laptop.
    • Remove the ribbon that connects to the laptop.
    • Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Aryn Pauly
회원 가입일: 04/29/10
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-42, Garner Spring 2010 Cal Poly, Team 10-42, Garner Spring 2010 회원
CPSU-GARNER-S10S10G42
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 8,376
