소개
This is a very difficult guide by the average user and is recommended to double check the power source as well as the power cable.
If the device is still running, please turn the computer off properly and then disconnect the power supply from the power supply port in the back of the computer.
Remove battery before beginning any work to reduce electrical shock and to prevent damage to the electrical components.
Locate and slide the 2-battery locks to disconnect the battery.
Remove the battery by sliding it out away from the computer (horizontal with the casing).
Remove the RAM cover panel screws with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
Using your fingers, push the RAM tabs that secure the RAM tabs outward (away from the RAM). The RAM should then pop up, gently remove the RAM pulling away from the connection. (Continue this process until all RAM has been removed from the device).
Remove the panel screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
The hardware to the left (labeled) can be easily removed by disconnecting the black and white wires and pushing the tabs that secure it (located on the side) outwards.
Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
Remove the 2-screws on the upper outer edges of the keyboard with a #1 Phillips head screwdriver.
Using a flat edge tool, begin to pry the keyboard from the laptop on the upper outer edges then slowly lift the keyboard away from the laptop until you are able to remove the ribbon that connects the keyboard to the laptop.
Disconnect the video cable near the left speaker slowly but firmly pulling upwards.
Disconnect the brown ribbon that is located directly in the middle of where the keyboard one was away from the connector.
Disconnect the 2-other white ribbons located near the top right half of the keyboard section pulling firmly away from the connector.
Unscrew the 2-screws located above the power button logic board with a #1 Phillips head screwdriver.
Using a flat edge tool, and your index finger began to slowly move the logic board out of it's slot.
Disconnect the white ribbon connected to the power button logic board, pulling firmly and steadily.
Reverse the order after installing the new power button logic board.
