이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This is a very difficult guide by the average user and it is recommended to double check the power source as well as the power cable.
필요한 것
Turn the computer off and disconnect the power supply from the power supply port in the back of the computer.
Locate the two battery locks and slide to disconnect the battery.
Pull the battery (with casing) horizontally away from the computer to remove.
Unscrew the RAM cover panel screws with a #1 Phillips head screwdriver. Then pry the RAM cover panel off with a flat edge tool.
Push the tabs that secure the RAM outward (away from the RAM) using your fingers. The RAM should then pop up.
Pull the RAM away from the connection to remove. Continue this process until all RAM drives have been removed from the device.
Unscrew the Wi-Fi panel screw with a #1 Phillips head screwdriver. Then pry the cover panel off with a flat edge tool.
Disconnect the black and white wires. Then push the tabs outward (away from the Wi-Fi card) using your fingers. The card should then pop up.
Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
Unscrew the two screws on the upper outer edges of the keyboard with a #1 Phillips head screwdriver.
Pry the upper outer edges of the keyboard from the laptop using a flat edge tool.
Lift the keyboard away from the laptop and remove the ribbon that connects the keyboard to the laptop base.
After installing a new power button logic board, follow these instructions in reverse order to reassemble your device.
