소개
Learn how to replace your laptop's RAM.
필요한 것
Use a #1 Phillips head screwdriver to remove the screw on the middle right of the RAM's cover panel.
Then, use a the blue iFixit Opening Tool to pry the cover panel off.
Push on to the RAM tabs to disconnect the RAM form the device.
The RAM will pop off from the socket. Gently pull the RAM out of the socket.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
