이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will be referred to for other steps because disconnecting the power to your computer is crucial to do before working on it. There are two spring-loaded switches that lock the battery into place.
Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
Slide the unlock switch in the top left-hand corner to the left/unlock position.
거의 끝나갑니다!
결론
