주요 콘텐츠로 건너뛰기
Toshiba Satellite M55-S135 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite M55-S135 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Use the Phillips 00 screwdriver to remove the 3.62mm screw.
  2. Toshiba Satellite M55-S135 Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the plastic cover from the laptop.
  3. Toshiba Satellite M55-S135 Hard Drive Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the black plastic tab horizontally away from the hard drive to disconnect and remove the hard drive from the laptop.
  4. Toshiba Satellite M55-S135 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Use the Phillips 00 screwdriver to remove the four 6.50mm screws on the sides of hard drive.
  5. Toshiba Satellite M55-S135 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite M55-S135 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Use the Phillips 00 screwdriver to remove the other four 6.50mm screws on hard drive.
    • Remove the washer strips (the metal strips that the screws held down) from the hard drive.
  6. Toshiba Satellite M55-S135 Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the black tab away from the hard drive to separate the hard drive and the casing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Matthew Trinh
회원 가입일: 01/31/13
63 평판
안내서 4개를 작성함
Cal Poly, Team 7-11, Maness Winter 2013 Cal Poly, Team 7-11, Maness Winter 2013 회원
CPSU-MANESS-W13S7G11
4 회원들
안내서 5개를 작성함
댓글 2개
I have a regular SATA 2.5 hard drive and it won't fit my M55-S1001. Is there something else I need??
Matthew Halbert - 답글
According to http://www.rakuten.com/prod/120gb-hard-d..., your hard drive is the right size. If it doesn't fit, check to see if the pins connect correctly and if your laptop accepts a SATA drive and not a PATA drive; this image can help http://www.laptopking.com/sata_identify.....
Next, check if you're inserting it correctly. I haven't experienced replacing the hard drive with the M55-S1001, but I assume it's the same method as the M55-S135 (though it could be different).
I'm unsure if there's anything else you would need besides the correct type of screwdriver to unlock the casing but I doubt it.
Matthew Trinh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 4,011
